Activity Forums Adobe Illustrator CS6 brush size under 1 pixel?
  • CS6 brush size under 1 pixel?
    Posted by Alistair Gallop on July 29, 2012 at 2:35 pm
    In CS6, it doesn’t seem possible to set the brush size under 1 pixel (i.e 0.5px). Does anyone know how to fix this as I require finer brush strokes than 1 pixel?
    Cheers
    Ali
    Vincent Rosati replied 14 years ago 2 Members · 1 Reply
  • Vincent Rosati
    August 21, 2012 at 12:45 am
    Could you create your own brush that is smaller that 1 pixel, or set the brush size to a very small decimal in the brush palette options.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
