Activity › Forums › Adobe After Effects › CS6 animated Mask with background bug
  • CS6 animated Mask with background bug
    Posted by Greg Passard on September 7, 2012 at 9:41 am
    After pasting mocha shape onto different layers, the animated masks are displayed with a kind of overlaid background, delimited by the size of each mask. So I have overlaid square and rectangle moving over tracked masks. The problem occurs during RAM preview and render.
    Any suggestion are welcome
    thanks
    Greg Passard replied 14 years ago 2 Members · 3 Replies
  • Greg Passard
    September 7, 2012 at 10:45 am
    Better than words
  • Ross Shain
    September 12, 2012 at 5:19 pm
    Have you tried doing: edit>paste mocha mask?
    This will allow you to paste from mocha directly to AE mask channel.
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Greg Passard
    September 12, 2012 at 6:02 pm
    Hi Ross, thanks for your answer. The “paste mocha shape” command is the one I used, and it works like a charm.
    I’ve found this WE, that a plug-in, neat video to name it, was at the origin of the bug.
    I’ve applied it in a different way which make the mask work normally.
    I think I certainly have to upgrade my memory setting.
    thank you.
