Activity › Forums › Adobe Encore DVD › CS6 and no Library Media Buttons
Posted by Chris Tompkins on May 14, 2012 at 3:14 pmUn-installed CS5.5
Installed CS6
Mac OS 10.6Encore, Loaded the second media disc for media content for Encore.
I don’t have any buttons…I don’t understand this.
Any guidance here please?Here a pic of Menu media:
And a pic where the buttons media should be:
Thanks.
Chris Tompkins
Video Atlanta LLCRajesh Barnabas replied 11 years, 9 months ago 8 Members · 16 Replies -
Stan Jones
May 14, 2012 at 3:42 pmWe’ve been told on the Adobe forums that the CS6 library is not yet available, and will be available very soon by download.
Very oddly, the Encore 5.1 library is deleted when CS6 is installed.
Also, they are returning to the method where a very minimal library is installed from disk, and the regular library is installed from the functional content disk – except it ain’t there.
So for now, copy from/point to an older version. If you haven’t installed CS6, copy your 5.1 to a safe location.
Stan Jones
Chris Tompkins
May 14, 2012 at 3:53 pmAppreciate the update Stan.
Very lame on Adobe’s part imo.
Chris Tompkins
Video Atlanta LLC -
Ron Pestes
May 15, 2012 at 3:04 amI have the same problem but I had it with 5.5 too. Talked to Adobe support today and they had the same problem too! They said they would bump it up to higher techs and call me back tomorrow.
ronpesteshdvideo.com
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
Dell M6600
Adobe CS6 Production Premium -
Shuchi Shrivastava
May 15, 2012 at 7:51 amThe complete functional content would be available as a separate download.Meanwhile, before installing the CS6 Functional content, backup your 5.1 content to a safe location and if you already have 5.1 content you could point the CS6 library to its location.
If your 5.1 is deleted while installing 6.0 content – copy the cs6 library from C:Program FilesAdobeAdobe Encore CS6Library and place it at another loacation and rename it.
Now uninstall the CS6 Content and reinstall the 5.1 FC using the disc or the downloded FC you have. In this way you will recover back your 5.1 FC and can also use the 6.0 FC by pointing Encore to its location. I tried it and this works.And this problem will no longer be faced once the downloadable full version of CS6 FC will be available
Ron Pestes
May 15, 2012 at 3:40 pmThe only problem is that I can’t find it on the 5.5 disc either. The content disc just has a bunch of PDF’s in different languages but I can not find anything about extra content even though the disc is labeled “Content”.
Sony EX-3
MacBook Pro
Dell M6600
Stan Jones
May 15, 2012 at 5:07 pmFor CS3 through CS5.5, the library installed with the program, not as functional content.
So, I think that doesn’t work I wonder if a repair install (for someone with CS5.5 still installed) would add the library back to CS5.5?
Stan Jones
Edwin Baldwin
May 17, 2012 at 3:08 pmAdobe posted this solution:https://helpx.adobe.com/x-productkb/multi/library-functional-content-missing.html
I have not had a chance to try it.Ed B
Edwin Baldwin
May 17, 2012 at 3:33 pmSorry about that.
https://helpx.adobe.com/x-productkb/multi/library-functional-content-missing.htmlEd B
Edwin Baldwin
May 17, 2012 at 8:10 pmI just downloaded and installed (win7 64x) and got the same results … Menu contents only, no buttons…. The Document was updated 2012-05-16 but apparently it did not solve the problems or it was not updated.
Ed B
