Activity Forums Adobe Premiere Pro CS6 – Actions and/or Saving Filter Settings
  • CS6 – Actions and/or Saving Filter Settings
    Posted by Al Jensen on April 22, 2013 at 8:12 pm
    I’ve never accidentally come across any Actions in Premiere (a la Photoshop), but I thought I’d at least make an attempt to ask in case I’ve been missing it all these years.
    At the end of all of my clips I make post-credit rolls which I can use on YouTube to highlight other videos. These require scale/position/etc for multiple videos every time, with only a couple of different variants. If I could just create an action that quickly put the video in the correct location at the correct size it would save me a tremendous amount of time in the long run. Even if I could just save the effect settings under multiple versions of “Motion” that would be plenty good.
    Any ideas? 🙂
    Al Jensen replied 13 years, 4 months ago 4 Members · 6 Replies
  • Angelo Lorenzo
    April 22, 2013 at 8:30 pm
    I would save this template with placeholder video as its own project for you to import into your working project. From there you can load your real footage in the source monitor and then in the timeline right click and select Replace Clip > From source monitor.
    This is one of those things that works super well as a template.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Al Jensen
    April 22, 2013 at 8:49 pm
    That’s a darn good idea. Thanks so much!
  • Tim Kolb
    April 22, 2013 at 8:53 pm
    Just set up the motion/scale effect the way you want it and right-click on “motion” in the Effect Controls panel, and save the preset…”credit-right side center” a separate one for “…left side center” or whatever.
    They should then be in your “presets” folder in the effects panel for later use.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Al Jensen
    April 22, 2013 at 9:06 pm
    Ah, I knew there must be something like this! This is great as well.
    Both of the suggestions have their benefits, but I think this is one of those things I’ll start using all the time. Thanks so much.
  • Paul Neumann
    April 23, 2013 at 5:07 pm
    You can also control/command highlight multiple effects and save them all off as a single preset.
  • Al Jensen
    April 23, 2013 at 7:37 pm
    Ah, that makes it even better. Great stuff.
