Activity › Forums › Adobe After Effects › CS5.5 Upgrade – 32 bit machine
  • CS5.5 Upgrade – 32 bit machine
    Posted by Gary Dumill on January 10, 2012 at 11:58 am
    MacPro1,1
    Dual-Core Intel Xeon
    Number Of Processors: 2
    Total Number Of Cores: 4
    2.66 GHz
    Memory: 8 GB
    32 bit.
    The machine is in need of an AE update. But I only have the option of upgrading to CS5.5 from the adobe site, which requires a 64 bit system. I’m having trouble finding an update to CS4.
    I’m aware that when you purchase production premium of a PC, that you get a copy of CS4 to resolve this problem.
    Is this also the case when it comes to upgrading only AE, to CS5.5 on a mac?
    Or are there any other options to upgrade?
    Thank you in advance..
    Kind regards
    Gary
    Kevin Camp replied 14 years, 8 months ago 2 Members · 2 Replies
  • Kevin Camp
    January 10, 2012 at 4:10 pm
    osx has a 64-bit kernel, so 64-bit should not be a problem. but you need to check the version of the os to make sure that is supported but cs5.5. i believe that cs5.5 works with leopard and up, but do double check that.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    January 10, 2012 at 5:11 pm
    a definitive option is to download the trial of cs5.5 and see how it works on your machine.
    i do think you’ll want to get more ram.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
