Activity Forums Adobe After Effects CS5.5 stereo audio becomes mono
  • CS5.5 stereo audio becomes mono
    Posted by Jan Van den bossche on October 6, 2011 at 6:59 pm
    working in CS5.5 on a MacPro.
    I render a comp with a stereo audio file to a QT Movie with any codec, settings are stereo 16bit, the audio output mapping is set to Left:Out1 Right:Out2 Then I import this movie file in FCP7. There it shows up as 2 mono channels.
    Where did I go wrong?
    Jan
    Jan Van den Bossche
    Jan Van den bossche replied 14 years, 10 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    October 6, 2011 at 7:27 pm
    Chances are it’s a setting in FCP. I’m not familiar with it to say where it might be, but FCP may be set by default to import “stereo as mono” and break up the tracks.
    You could also look play it in quicktime, make sure in the movie inspector that it lists one stereo track and not two separate mono tracks.
    – Angelo Lorenzo
    https://FilmsFor.Us Sell your film and connect with your audience
  • Jan Van den bossche
    October 7, 2011 at 6:57 am
    thanks for your reply.
    I do think the problem is created somewhere in AE because it concerns only movies that are being rendered in CS5.5 (don’t have the problem with CS4).
    Other movies I get that are not from AE show up as stereo.
    But when I open these movs in QT Player, the info window tells me it’s stereo.
    Strange
    (I think)
    Jan Van den Bossche
  • Andrew Vallario
    October 10, 2011 at 7:55 pm
    I’m having the same issue. I didn’t realize it until I got a call of the dup house. Any ideas??
    -AJ
    October 11, 2011 at 7:21 am
    I’m not alone, that’s a relief :o)
    Now hoping that some genius finds a solution!
    Jan Van den Bossche
