Activity › Forums › Adobe Premiere Pro › CS5.5 not outputting to External monitor.
Posted by Kyle Barrett on June 30, 2011 at 5:07 pmHello all, I’m attempting the switch from FCP to Premiere and am having issues being able to playback through my Decklink Extreme to my production monitor. All the latest blackmagic drivers are installed and I can see Blackmagic presets available under the capture options but when I check playback settings they are non-existent. Any thoughts?
Alfred Guzzetti replied 14 years, 7 months ago 9 Members · 17 Replies -
Kevin Monahan
June 30, 2011 at 6:09 pmAre your clips in a BlackMagic sequence?
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Kyle Barrett
June 30, 2011 at 6:42 pmI wasn’t but I just created a new project and used the following settings.
Capture Format: Blackmagic Capture
Sequence Preset: Blackmagic Digital SLR 23.976Create a sequence, import some clips, drag one into the timeline and now the program viewer remains black and will not playback the timeline, nor does it play out to the monitor and when I attempt to look at the playback settings window instead of getting the window like the one in my original post the only thing that comes up is a small window asking whether or not I want to turn off a drop frame warning.
I appreciate any advice you may have.
Tom Daigon
June 30, 2011 at 7:13 pmUner Preference – Playback setting make sure you have the drop down option for Blackmagic (drivers). If you dont, you need drivers that support 5.5, which many vendors are working on now. Check their website for new downloads. If not, contact them.
Tom Daigon
Avid DS / FCP / After Effects Editor
http://www.hdshotsandcuts.com -
Thomas Kreuer
July 1, 2011 at 11:29 amHi Kyle,
we’re having the same problem. Want to switch from FCP7 to PP5.5 but without preview on clients monitor that doesn’t make sense.
We are now experimenting with older driver versions…Thomas
Thirty Seconds Filmproductions
http://www.thirty-seconds.tv -
Peter Blumenstock
July 1, 2011 at 2:21 pmHi Thomas,
fellow German switcher from FCP to Premiere here (though also looking at Avid).
I managed to get results with both, AJA and BMD. There are still issues and it isn’t as smooth as we are used to with FCP but it is doable and there’s a good chance now it will get better. What are your settings? What material are you using?
I am currently in an all-prores workflow because of all the FCP stuff. What works best for me is to go with an uncompressed setting from the AJA or BMD presets, that gives me the most stable output. Let me know, glad to help where I can. -
Kyle Barrett
July 1, 2011 at 2:32 pmEverything I’ve read is that in order for CS5.5 to work you need the Blackmagic Desktop Video driver version 8 or higher and I have 8.0.1. Which it would just “work” I’ve been spoiled over the years by FCP. We edit RED, Alexa ProRes and Canon DSLR footage and it kills me that I can’t just set my playback settings like I could in Final Cut.
_____________________________________________________________
KYLE BARRETT • video editor • 813.253.0300 • spark.us
Tom Daigon
July 1, 2011 at 4:10 pmI thought I would chime in with info on the new AJA drivers for Adobe. They are up and running and allow display of PP, AE and PS on an external monitor.I am using Kona 3 with a Panasonic 2600W. It works great!
Heres the link..
https://www.aja.com/support/konaNEW/kona-3-3x.php
You need the Kona drivers 9.0.3 AND the Adobe Plugin drivers 9.0.1.
Tom Daigon
Stephen Les
July 4, 2011 at 9:49 pmI am using the newest drivers (9.0.4) and plugins (9.0.1) and the Kona 3 is not outputting to a G series JVC reference monitor via SDI. Also, I have a lot of 1080p29.97 material and there is no AJA preset for it. That’s why I’m installing Avid Media Composer as soon as I can and hoping for a better experience converting from FCP.
John Pale
July 6, 2011 at 12:58 pmHow will installing Avid help you? Avid does not work with the AJA Kona 3 at all?
Alfred Guzzetti
August 26, 2011 at 5:06 pmI installed the Blackmagic 8.2.1 driver yesterday and still have the same problem that the others have: no moving image from the timeline or program. The Adobe info is unhelpful.
Alfred Guzzetti
Mac Pro Quad 2.66GHz 4GB RAM
Intensity Pro card
OS 10.6.3
FCP 6.0.5
DVDSP 4.2.1
