Activity Forums Adobe Premiere Pro CS5.5 Improving playback without Mecury?
  • CS5.5 Improving playback without Mecury?
    Posted by Thomas Vailly on January 30, 2012 at 3:39 pm
    Hello,
    I have a gx700 laptop and I just installed CS5.5 on windows 7 64bits
    I need to edit footage from a Canon 550d / t2i, 1920x1080p
    Processor: 2.4gb X 2
    4Go Ram
    Nvidia 8600M GT (512mo Ram)
    As expected, playback isn’t smooth.
    My playback settings / Aspect ratio conversion : software
    Nvidia 8600M GT (512mo Ram) do not support Mercury playback
    Playback resolution: 1/4 (1/8 & 1/16 are grey
    In Sequence settings video preview
    I reduce the resolution but no improvement in playback!
    Do you have any idea for me to improve the playback (by reducing quality? I don’t want to convert all my footage!
    Thx
    Thomas Vailly replied 14 years, 6 months ago 3 Members · 4 Replies
  • Ramil Pasibe
    January 31, 2012 at 5:16 pm
    You could try transferring all your media/RAW material files into an external RAID 0 drive, accessed via E-sata or USB 3 (If your laptop has these ports). That should give your editing experience a bit of a boost. If you don’t then your out of luck. If you are not short of time, you could also try a fresh reinstall of the system and the Adobe Suite.
  • Thomas Vailly
    January 31, 2012 at 10:55 pm
    So I have improved my workflow by creating a seqeunce with all my rush.
    Then I reduce by half the “preview settings” of this sequence
    Then I render all work area
    As a result a lower quality of all my footage are saved in the scrape disk. So I can go smoothy throught my sequence.
    PROBLEM…
    As soon as I edit my sequence, the preview file is not used anymore and playback is not smooth!
    Is there is a way to use placeholder / proxy (low resolution footage) like in After effect?
  • Alex Udell
    February 3, 2012 at 9:16 am
    Well…that is sort of like converting all your footage….
    which you said that you didn’t want to do?
    Alex
  • Thomas Vailly
    February 7, 2012 at 11:18 am
    Well, since I seem not to have any other option… why not.
    I mean, CS5.5 is much smoother on my computer than CS3 with everything but PREMIERE.
    So, I’m looking for a convenient workflow to have… preview low res footage than I could edit / apply effect. Then I want to be able to swap to full resolution when rendering.
    Exactly like proxy in after effect.
    Any idea?
