Activity Forums Adobe After Effects cs5 vs cs6 render speed
  • cs5 vs cs6 render speed
    Posted by Aaron Pozzer on November 7, 2012 at 1:53 pm
    so i had to rerender some stuff for a client yesterday. the original work was done in cs5, but i had 6 going then so i figured ill just render in 6.
    opened the project, set it going and it was going realy slow. i thought i dont remember it taking this long originally. so i did a test of rendering the same 10 frames in 5 and 6. it was a pretty large project with lots of 1920 frame sequences, lens blur plugin, optical flares, expressions, etc.
    anyway, maybe it was my imagination. cs5 rendered with 68% ram usage, in 4:51 min. 6 did it with 59% ram usage in 4:33 min. i made sure the memory/multiprocessor settings were the same, so it should be a pretty fair test. i also purged the cs5 cache after rendering just incase.
    anyway, just wondering if anyone else has done any testing of 5 vs 6 render speeds? are they significantly better? the same? seems like a small increase in speed, but not significant. 20 seconds in 5 min would only save you 10 min out over a 2 hr render (estimate, my math sucks).
    Aaron Pozzer replied 13 years, 10 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    November 7, 2012 at 3:10 pm
    I think a better test would be one where you render after you worked a bit on the project in CS6 and you have some cached layers. CS6 will make use of that and your final render will be much faster.
    https://www.adobe.com/products/aftereffects/global-performance-cache.html
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Aaron Pozzer
    November 7, 2012 at 4:29 pm
    dunno, that seems like a cheat. if you just wanna compare apples to apples performance, i think it makes more sense to just load up the project and go for it. its nice to have the benefit in 6 if stuff is cached, but thats not always the situation when rendering.
