Activity › Forums › Adobe Premiere Pro › CS5 to CS6 Link Media problem after “Collect Files and Copy to New Location”
  • CS5 to CS6 Link Media problem after “Collect Files and Copy to New Location”
    Posted by Joe Marler on June 20, 2013 at 4:54 pm
    A CS5 project was saved via Project Manger->Collect Files and Copy to New Location. That folder tree was taken on a portable hard drive to another PC running CS6, where I get numerous errors trying to open the project:
    – “Where is the file 00032.m2t?”
    I then tell it the location, which then gives the error:
    – “Where is the file 00032.xmp?”
    When I tell it the file location, it then gives this error:
    – “File import failure”, “File format not supported”
    I then click cancel, it loads the project, but many clips are red “Media Offline”.
    For each of those offline clips I can right-click->Reveal in Project, then in the Project Panel, right-click->Link Media, point to the the media and it loads it.
    However many of these clips are all in the same folder — the folder CS5 put them during “Collect Files and Copy to New Location”. Even those in different folders are in the place CS5 put them.
    How do I avoid laboriously re-linking each file? I thought the entire purpose of “Collect Files and Copy to New Location” was to avoid this?
    Alex Udell replied 13 years, 3 months ago 2 Members · 2 Replies
  • Alex Udell
    June 20, 2013 at 6:46 pm
    in a nutshell…
    If you get into a project with a number of media items not linked…
    it’s possible to expose the media status as a column in project panel.
    (might need to go to project panel metadata to show it)
    then if you do a quick search for “offline” (via the field at the top of the panel) it will show only those items.
    If you multi-select them and right click re-link…
    then find the first one…
    and the others are in the same folder…
    it ought to find them….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Alex Udell
    June 20, 2013 at 6:59 pm
    I guess….my point on above…
    unlike AE….which will add all missing if one found…
    unless all missing are selected first in PPro…
    only the selected will be relinked…
    Alex Udell
