Activity › Forums › Adobe After Effects › CS5 simple opacity dissolve
  • CS5 simple opacity dissolve
    Posted by Adam Chesbrough on November 10, 2010 at 9:39 pm
    I am about to throw my computer out the window. I simply want to do an opacity dissolve with two seperate jpegs in the AE CS5 timeline. The preset fade in+out-frames works for some images, I have also simply keyframed in the opacity changes at the end of the top clip and overlapped the bottom clip
    regardless of how I do it I get a dither dissolve. I have checked all the clip settings and there is nothing that I can see that would make this happen. I have included a screen show of what the dither dissolve is. Any help would be greatly appreciated. Thanks
    macbook pro 17″ i7, 8GB RAM
    esata external HD 7200RPM
    canon 5D mark II, 24-70mm, 50mm, 15mm fisheye, juicedink DT454, zacuto striker
    Adam Chesbrough replied 15 years, 10 months ago 2 Members · 2 Replies
  • Kevin Camp
    November 10, 2010 at 9:57 pm
    make sure that the blending mode is not set to ‘dissolve’ (layer>blending modes, set to ‘normal’).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Adam Chesbrough
    November 10, 2010 at 10:18 pm
    That was the solution, I was confused as I couldnt find the “layer properties” next to or around the clip within the timeline and more so since the preset animation had a composite layer option…Either way, I really appreciate your help.
