Activity Forums Adobe After Effects CS5 rotobrush question
  • CS5 rotobrush question
    Posted by Kelly Huffaker on May 20, 2010 at 5:25 am
    I’m just dabbling with the new Rotobrush feature in AE CS5. I just wanted to make sure that I am getting this flow correct. After I finish rotoing what I need done, and tweaking with it whenever the roto is off, I hit “freeze” to render it out onto it’s own layer? So If I wanted to use the roto layer as a mask for the layer underneath what do I do? I’m trying to do an overly-used skit involving lightsabers and the Andrew Kramer preset. Sometimes the lightsaber will pass behind the subject, and so I need to mask out the subject. I figured that I can use the new Rotobrush to my advantage. THanks guys
    Canon 550D, 50mm 1.8, 28-135mm, Adobe CS4 Production Premium, Neo Scene, Velbon DV-7000
    Todd Kopriva replied 16 years, 3 months ago 3 Members · 2 Replies
  • Adriano Moraes
    May 20, 2010 at 12:32 pm
    I don´t know your outcome but I risk to say I would use a duplicate of the “roto-tooled” image (tinted black or white) as a mate for the saber.
    Hope I´m not talking nonsense.
    Cheers!
  • Todd Kopriva
    May 20, 2010 at 2:52 pm
    The workflow with the Roto Brush effect isn’t really any different than the workflow with any transparency-creating effect (e.g., keying effects) in this regard. By using the Roto Brush effect, you create a matte. You can use this layer as an alpha matte for another copy of the layer.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
