Activity Forums Adobe After Effects CS5 Rendering MPEG2 Problem: Time Sensitive
  • CS5 Rendering MPEG2 Problem: Time Sensitive
    Posted by Robert Till on July 28, 2010 at 7:11 pm
    Long post short. I’m trying to render a 30 minute video in MPEG2 from a PSD Sequence, Audio File, and 1 other QT movie. It works fine on the work iMac (3.06 GHz, 4GB 1067 RAM) but when i try from my personal laptop it tries for a few minutes then says UNKNOWN ERROR (-1610153453)
    My laptop is running 10.6.4 with 2.5 GHz Intel Core 2 Duo and 4GB 667 DDR2 SDRAM
    I have a multitude of these to do, and only the iMac to utilize so I enlisted my personal laptop to help out. (I am acutely aware that this is not a desirable set up)
    Any insight would be IMMENSELY helpful
    Rob
    Robert Till replied 16 years, 1 month ago 2 Members · 6 Replies
  • Robert Till
    July 28, 2010 at 7:13 pm
    Side note I should mention, I’m keeping the files on an external hard drive with a FireWire 800 connection while working from the laptop. Would that cause this?
  • Robert Till
    July 28, 2010 at 7:22 pm
    Thanks for the quick response, I’ll give it a shot right now.
  • Robert Till
    July 28, 2010 at 7:33 pm
    Would you suggest trying to downgrade back to 10.6.3 for the time being?
  • Robert Till
    July 28, 2010 at 8:07 pm
    Hmmmm, I haven’t really experienced any issues like that. Only the render problem. But I’m going to stick with what you mentioned, it seems like that’s doing the trick.
    Thanks Dave.
  • Jacques Davis
    July 29, 2010 at 6:07 am
    try to render without the audio, if it works then export the audio (wav) then mux with tsmuxergui
  • Robert Till
    July 29, 2010 at 2:08 pm
    Follow up status report. I tried rendering with turning OpenGL on, which I thought was standard, and everything’s working fine again.
