Activity Forums Adobe Premiere Pro CS5 render output Variable frame rate?
  • CS5 render output Variable frame rate?
    Posted by Thomas Wildgen on February 21, 2013 at 3:38 pm
    Does anyone have an idea what could cause the render (using adobe media encoder)of footage to come up as variable frame rate? I have been rendering many programs from footage shot on the same cameras on the same day and rendered in a queue and the others show in media info as constant frame rate? The ones that have come up as variable are not uploadable to the CDN we use.
    Roger Wright replied 12 years, 8 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    February 21, 2013 at 5:37 pm
    What format are you rendering and what are you using to watch those files?
  • Thomas Wildgen
    February 21, 2013 at 7:35 pm
    Rendering to MP4 format, 720×480, 29.97 fps interlaced, using the main profile. most are fine, but I see about 12 programs out of more than 50 won’t upload. when using Media Info to check:
    Won’t upload to CDN
    Frame rate mode : Variable
    Frame rate : 0.270 fps
    Original frame rate : 29.970 fps
    Minimum frame rate : 0.000 fps
    Maximum frame rate : 29.970 fps
    Programs that have NO issues:
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    I haven’t seen anywhere in the media encoder where you can select a Variable framerate. What am i missing?
  • Thomas Wildgen
    February 25, 2013 at 7:13 pm
    Update: I did find a setting in the render queue under file>interpret footage. It will allow you to render out in a variable framerate mode(?) However I am still getting a variable framrate file even when this function is NOT checked. It is only happening in 2 of the sequences that I am trying to render out. I was able to get a constant frame rate by selecting the interpret footage and specifiying 29.97. I assume that something in the original footage is triggering this? what should I look for?
  • Roger Wright
    January 15, 2014 at 4:47 pm
    Hmmm, tough to say really. Any chance you can post a screen grab of your presets?
    It might help to see what the queue is looking like. Sometimes the presets can get messed up and don’t reflect the same settings as the render queue. I don’t know about you, but i’ve seen it happen before.
    It’s likely something in the original footage triggering this as you’ve said, but without a screen grab its like shooting in the dark.
    -Roger
