Activity Forums Adobe Premiere Pro CS5 Real-Time output
  • CS5 Real-Time output
    Posted by Thomas Santopolo on May 1, 2010 at 5:56 pm
    For a real-time external monitor I know that the intensity card and the Matrox Mini will output in real-time, but their presets must be used. So if I edit AVCDHD with Premiere CS5 AVCDHD presets, I get
    great real-time performance, but if I use the Blackmagic presets (I have an intensity card)the performance not good. Is there any way to get real-time output on an external monitor (HDMI) using premiere presets? Otherwise what good are these devices if I have to use their codec? I have an I7-920 system with a GTX 285 card.
    Vince Becquiot replied 16 years, 4 months ago 2 Members · 1 Reply
  • Vince Becquiot
    May 1, 2010 at 7:17 pm
    The simplest way is to set your second display as extended in the OS display properties, then tell Premiere to use it for preview. That also may require a DVI to HDMI cable/adapter.
    That’s the only solution that won’t require making presets but it’s definitely not the same as using a dedicated card.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
