Activity Forums Adobe After Effects CS5 RAM preview issues
  • CS5 RAM preview issues
    Posted by Matt Darnall on August 1, 2012 at 10:16 pm
    I’m currently trying to ram preview and it only renders one frame. Purging doesn’t do anything, but when I restart AE it work for 5-10 previews, then once again stops working.
    I have 9 gigs of ram and the project is simple and shouldn’t be particularly taxing on the system.
    Thanks for any input
    m
    Roland R. kahlenberg replied 14 years, 1 month ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    August 2, 2012 at 2:41 am
    Officially, it’s a memory related issue though I’m doubtful that that’s the only cause for this issue.
    What are your MP settings like in the prefs? You could be setting aside too little RAM per CPU.
    If the comp has a simple structure then try playback via Spacebar. If you have a fast drive and a decent GPU, it’s pretty quick and saves the hassle of trying to troubleshoot the issue.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Matt Darnall
    August 2, 2012 at 3:37 am
    Unfortunately I’m working with audio, so a space bar preview won’t work for me.
    August 2, 2012 at 4:04 am
    I suggest that you do one of the following –
    1) rename the AEP
    2) copy/paste the layers into a new comp
    3) use Dynamic Link to PPro and use PPro’s timeline for your playback
    And as suggested earlier, it would be useful if you told us your MP settings.
    HTH
    RoRK
