Activity Forums Adobe Premiere Pro CS5 Premiere gets stuck exporting to 96%
  • CS5 Premiere gets stuck exporting to 96%
    Posted by James Siv on September 24, 2010 at 7:30 pm
    Hello all! I took a break from film work for a few months when I got a side job. I come back and render out an old project (which I had exported several times in the past) in an HD format. Every time the file gets to 96% and it just stops. It doesn’t appear to be frozen, but it just sits there. When I hit cancel I get a message, only then, that Premiere is not responding. I’ve left it at 96% for about 20 minutes and it doesn’t do anything – despite saying I have 8 seconds left.
    I’ve tried many different formats (MPEG2, MPEG4, H.264). I ensured that I’m rendering in the correct framerate. I’ve restarted several times. No luck…
    I notice in the folder that I’m exporting to, I see three files. 2 files are identical in their naming system seems to be a random string of numbers (I assume 1 is for video, the other for audio). The third file is the actual output name, I enter when exporting. None of these can actually be viewed.
    I’d really appreciate any help you can give or even forward me to a place I might have more luck getting help.I’m running on Win7, CS5 Master Suite, 24gb of ram, NVidia Quadro 3800, 2 Intel Xeon E5506 2.13Ghz Quad-Core.
    Taylan Savaş replied 13 years, 11 months ago 4 Members · 6 Replies
  • Jon Barrie
    September 24, 2010 at 10:30 pm
    Just a quick diagnostic:
    Is the file size perhaps stalling with the 4gig limits if a FAT32 drive? Make sure the export is going to an NTFS drive (PC) or extended drive (Mac).
    Have you tried to export the last bit on it’s own? If there is a particular file that’s causing the problem the media cache may need a clean. Do this in Prefs> media> “clean” button, close ppro. Relaunch ppro. Then let the conforming etc to finish before working with ppro. Export.
    Let us know your results if it all works out.
    – Jon Barrie
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • James Siv
    September 25, 2010 at 6:41 pm
    Cleaning the cache worked! Thanks so much for your help
  • Cindy Munk
    September 16, 2011 at 2:05 am
    I am having the same exact problem – I have CS3 PP and it gets “stuck” rendering on the export at 99.96%. I tried cleaning the media cache but am still having the problem, and also deleted all temp files. I’m exporting as H.264, and as a side note, awhile back when I was using the V 2 pass, it was getting stuck, but when I switched to 1 pass, there was no problem rendering…until now. Any advice?
  • Jon Barrie
    September 16, 2011 at 4:06 am
    Just to get this thing out I would suggest you Export the whole thing out to Quicktime with the Animation Codec to get a Clean High Quality Export (will eat up the HDD) then use that to export to H.264, just to get it out. It could be a corrupted file at the end of the edit… But just to get the sucka out make an uncompressed export.
    I don’t do much VBR anymore.
    How much RAM do you have in the system?
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
  • Cindy Munk
    September 16, 2011 at 5:23 am
    Thanks for your advice Jon. I have 3.25GB of RAM – I was finally able to export it CBR, not really sure why it made a difference over VBR but it worked!
  • Taylan Savaş
    September 29, 2012 at 9:42 pm
    Using Cs6 and got 4hr 30min Hd video on timeline. Trying to export as h264 1080p. Waited like 5hrs to end of process and got stuck at %100 like 2 hr already. I’m exporting the video to NTFS formatted external HDD. Still it says 1 sec remaining.
    I can see the video cash files (65gigb.) but still there is no actual video.
    I Can not dare to cancel and redo all things from start.
    I’d really appreciate any help.
    I have 6Gb Ram and 2 gb Geforce 630m video card.
