Activity Forums Blackmagic Design CS5 & Intensity perfromance
  • CS5 & Intensity perfromance
    Posted by Randy Johnson on May 8, 2010 at 6:01 pm
    I have a question I have a i-7 with 6 gigs of memory and a Intensity pro card with CS5. When I edit AVCHD the dissolves are fine in RT but a slide or some kind of push effect drops frames. Also if I do a PIP it slows to a crawl. Anyone else have these issues? How important is drive speed to AVCHD editing? Do I need a RAID or is a fast single drive enough?
    thanks
    Randy
    Randy Johnson
    Rando1968@comcast.net
    Richard Perry replied 15 years, 9 months ago 6 Members · 15 Replies
  • 15 Replies
  • Thomas Santopolo
    May 10, 2010 at 1:52 am
    I don’t think that using the blackmagic presets work with the adobe mercury engine. I can’t get any performance out of their presets, but if I use adobe AVCHD presets I get 8 layers real time. I also have an i7, GTX-285, 12GB memory and raid. I searched their website but there really is no help there. I even tried using cineforms codec but no go. I think matrox is the only card (with the max option) that can edit in real time and have broadcast video output.
  • Kristian Lam
    May 10, 2010 at 3:14 am
    Hi Randy,
    What kind of graphics card do you have installed?
    regards
    Kristian Lam
    Blackmagic Design
  • Randy Johnson
    May 10, 2010 at 3:51 am
    Nvida GTS-250 and I Nvida 9800 on my other machine.
    Randy Johnson
  • Randy Johnson
    May 10, 2010 at 4:44 pm
    I know I am not taking advantage of the MPE but I should still be able to get a 1 second “slide” right? Without the BM timeline I get great RT even in “full rez” I dont understand MB constantly says there cards just give a an output they dont do anything which if true then why is the computer MUCH faster without it? It definatly seems to be slowing something down.
    Randy Johnson
  • Thomas Santopolo
    May 11, 2010 at 1:02 pm
    Kristian,
    Any way to output through the intensity card using any of Adobes presets, or adding some similar presets to yours? I have the Cineform software and First Light outputs through the intensity card which is great for color correction, but those files will not playback in real-time with your presets. It seems that it would be a big benefit for you guys, particularly sine Matrox is saying they offer real-time multilayer editing, to do something like this. I don’t think you even have a tool that will convert a video file to your format.
  • Robert Falkowski
    May 12, 2010 at 8:21 am
    [Thomas Santopolo] “I don’t think that using the blackmagic presets work with the adobe mercury engine”
    OMG! Is this true? Reading this:
    https://forums.creativecow.net/readpost/124/873752
    I was fooled that BMD cards work with Mercury playback.
    Robert Falkowski – http://www.mmstudio.com.pl
    System: Windows7 HP(x64), Edit soft: Adobe CS3 Premium, Video: BM-D Multibridge Pro (rev1), CPU: Core i7@3,8GHz, chipset: X58, RAM: 6GB DDR3, VGA: 8800GTS, HDD: 1x500GB + 4x500GB raid0, VTR: BetacamSP: UVW1800P, Dvcam: DSR-11P.
  • Randy Johnson
    May 12, 2010 at 6:56 pm
    Id there any advantages of upgrading from the Intensity pro to the Intensity shuttle?
    Randy Johnson
  • Kristian Lam
    May 13, 2010 at 7:57 am
    Hi Robert,
    We absolutely support the Mercury Playback Engine and have been working with Adobe for some time now to incorporate this into our drivers. From the issues described here, it sounds like a bug or some setup issue which I hope I can help resolve.
    regards
    Kristian Lam
    Blackmagic Design
  • Kristian Lam
    May 13, 2010 at 8:01 am
    Unfortunately, no. The architecture of Adobe Premiere Pro is such that we have to provide the presets. You can’t just use an Adobe preset and opt to output via our cards.
    I hope to be able to add some Blackmagic AVCHD presets that will output via our cards, which will in turn also support the Mercury Playback Engine if you have a compatible graphics card.
    Randy, since you have your email listed in your signature, I hope you don’t mind someone from Blackmagic send you a patch build sometime to see if performance improves.
    regards
    Kristian Lam
    Blackmagic Design
  • Thomas Santopolo
    May 13, 2010 at 12:24 pm
    I would also be happy to test any patches/updates. My email is tom@vtcomputech.com. Would really be great if you could support the cineform codecs.
    Tom
