Activity Forums Adobe InDesign CS5: Hyperlink doesn’t work
  • CS5: Hyperlink doesn’t work
    Posted by Rob Hruska on May 4, 2011 at 5:21 pm
    Here is my problem. It’s driving me up the wall.
    I have an InDesign document with hyperlinks in it that I export to PDF. All of the links work except one.
    1. If the text of a link is the same as the URL, it will work. That is, if the text is https://www.creativecow.com and the URL is https://www.creativecow.com, the link will work.
    2. If the text is an e-mail address (bessie@creativecow.com) and the URL is a mailto: to that address (like mailto:bessie@creativecow.com), it works.
    However, if the text is not the URL (say the text is “CreativeCow Link”, no matter what, the link won’t work.
    To create the link I do the following:
    1. Select the text
    2. In the Hyperlink panel, click “Create new hyperlink” button at the bottom.
    3. Choose “URL” from the dropdown list and paste the URL into the “URL:” field.
    4. Whether “Shared Hyperlink Destination” is clicked or not, it doesn’t change anything.
    If you select the text in InDesign, the link is highlighted in the Hyperlink panel, so InDesign knows it is supposed to be a link. The link does not work in an exported PDF.
    Additionally on a semi-related note, I cannot post this to the Adobe forums. Apparently I have to register the software to be able to post, and since I have a volume license I cannot register it, so I cannot post to their forums. Thanks Adobe.
    Jackie Watanabe replied 10 years, 11 months ago 6 Members · 5 Replies
  • Nancy Siegel
    September 14, 2012 at 3:06 pm
    Rob, I am having the same problem. Did you find a solution?
    Nancy
  • Susanne Murtha
    September 14, 2012 at 8:33 pm
    I’ve been working at this for hours and having the same issue. In most instances the text is other than the URL but in one instance it is the same but still doesn’t work.
    I’ve also tried checking and unchecking the shared box. I’ve deleted the hyperlink and put them in again in different ways with no success.
  • Chiali Tsai
    January 7, 2013 at 4:01 pm
    Hope you guys already found the solution, 😀
    here is what I did and it works.
    first, you draw a rectangle frame on whatever the text is and convert to a button
    2nd, add your action “go to url” and enter your link in the button panel ( and this stage, it wont work)
    3rd, go to your hyberlink panel and add new destination, enter the same link as you add on this button
    then it should work.
  • Andrew Seles
    July 8, 2013 at 5:40 pm
    I was experiencing the same problem and found that exporting as an interactive PDF resolved the issue (File > Export > Format: Interactive PDF).
    Requires tweaking the export settings if you’re trying to match High Quality Print profile. Really odd that mailto links and full URLs work using regular PDF presets.
  • Jackie Watanabe
    October 14, 2015 at 5:24 am
    I was having the same issue and then I tried this:
    You can save as a PDF (interactive) like another poster mentioned. However, I noticed I would lose a lot of quality in any images in my document. Instead, when you save as a PDF (print), when the ‘Export Adobe PDF’ prompt comes up, make sure that ‘Hyperlinks’ (under the ‘Include’ section) is checked.
