Activity Forums Adobe After Effects CS5, How do I create an ellipse-shaped composition, with transparency outside the ellipse?
  • CS5, How do I create an ellipse-shaped composition, with transparency outside the ellipse?
    Posted by Charlton Rom on April 29, 2012 at 7:04 pm
    My composition is a banner for a website, 570×82, several text layers, with glows and such, to more easily get a brighter and modulating look. I generated a Radio Waves stroke effect on text layer 6. No problem here—everything runs fine, but for some reason I can’t scale the stroke effect. It extends to the comp borders, which is too much. There are no parameters to scale the stroke per se, and scaling the layer doesn’t do a thing.
    Someone suggested pre-composing, I’ll try that if necessary but first I added another Solid layer: I’m trying to use Generate Ellipse to create a mask or screen to constrain the composition to that overall shape, and thus constrain the overweening stroke effect. But I’m having trouble deleting or screening what’s outside the ellipse. This kind of thing is easy in Photoshop, just invert the selection and delete, but how do I “delete” what’s outside the ellipse in AE, so it’s transparent, and my composition has an elliptical nature and look? Hoping someone has some notions—
    Houston TX
    Charlton Rom replied 14 years, 3 months ago 3 Members · 3 Replies
  • Kevin Camp
    May 1, 2012 at 5:19 pm
    using a second layer above the radio waves layer as a track matte should do it.
    make a new comp-sized solid and then add an oval mask.
    place the new solid above the radio waves solid.
    in the timeline, from the track matte (TrkMat) dropdown menu for the radio waves layer select ‘alpha matte’ and it should clip the radio waves to the alpha of the oval layer.
    if you don’t see the trkmat drop down, right-click near the top of the timeline (where is says ‘source name’) and choose columns>modes).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Wim Bruyninckx
    May 16, 2012 at 8:57 am
    my solution without precomposing:
    1. add an adjustment layer in your current composition and put it on top of your layer stack
    2. add a mask in that layer, (in your case an ellipse)
    3. add the effect > extract
    4. in the extract effect settings > check the ‘invert’ option
    this is a useful solution when you want to mask out a certain region in your comp, without precomposing (so all your layer relations stay intact)
    happy masking!
    Wim
  • Charlton Rom
    June 10, 2012 at 4:39 am
    Mr. Wim— thank you so much, I got depressed about ever finding a solution that didn’t involve an expensive tutor. Finally got into deadline situation and had to give it another go— you nailed it! Thanks!
