Activity › Forums › Adobe Premiere Pro › CS5 hangs after saving (I already have 5.03)
  • CS5 hangs after saving (I already have 5.03)
    Posted by Justin Parker on May 8, 2011 at 9:24 pm
    I’ve had Premiere CS5 on my system for months without a hitch.
    Now, on some projects Premiere hangs after saving. Other projects are fine. Project size seems to not be an issue. Some very small projects hang while other large ones do not. I know about the project bloat bug but I already have 5.03. Everything I find online about this issue relates to the 5.03 upgrade, but I’ve had it for months.
    Jules Oille replied 15 years, 4 months ago 3 Members · 5 Replies
  • Ann Bens
    May 9, 2011 at 8:00 am
    Try a re-install, see if that helps.
  • Justin Parker
    May 9, 2011 at 3:05 pm
    Tried the re-install. didn’t work
  • Ann Bens
    May 9, 2011 at 9:13 pm
    Reinstall windows did you try that?
  • Justin Parker
    May 9, 2011 at 10:31 pm
    I’m going to explore some more options before I reinstall the entire operating system.
  • Jules Oille
    May 31, 2011 at 4:35 am
    I called up Adobe Support. I was also having a load and hang issues. They told me to:
    1. Uninstall and deactivate.
    2. Use the CS5 removal tool
    3. Re-install
    4. Do not do a software update (the technician has no faith in his own updates).
    5. Swinging a dead chicken is optional
    It fixed most of the problem but CS5 still hangs with larger files. CS5 is an unstable piece of junk. You’d figure they have a stable movie editing system after all of these years.
    Good Luck Justin
