Activity › Forums › Adobe Premiere Pro › CS5 file size growing huge
Posted by Brogan De paor on August 14, 2010 at 5:33 pmWorking in CS5. Program file was approx 200 MB. Problems saving, froze.Had to force close. Slow to open – file size had grown to
4.8GB! Reverted to earlier version (still 200 MB), re-did work, it
grew to 1.7 GB. Tried another earlier version, to check file paths and settings, did no work – it grew to 3.7GB. Any ideas?
Was working on titles – overlapping rolling titles, when trouble started – connected? I think CS5 saves titles to the program file.
Have an HP with 17(930) and 12GB of RAM.
Thanks for any help.
BDPTodd Kopriva replied 15 years, 1 month ago 7 Members · 9 Replies -
Ann Bens
August 14, 2010 at 11:14 pmIts a bug.
A fix is on its way.
Dont ask me when, only Adobe knows. -
Todd Kopriva
August 14, 2010 at 11:56 pmWe’re working on it.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Jon Barrie
August 15, 2010 at 1:52 amIt seems to be connected with sequence renders. Dump all the renders from the sequence menu. Or import old project into a new one and make sure to delete render files. That should get u back on your feet while the adobe team get the fix sorted. 😉
Jon BarrieJon Barrie
aJBprods
Jon’s YouTube Tutorial Page
follow Jon with twitter -
Wolf
August 15, 2010 at 7:15 amHi,
do you have mp3?
i remarked, when i have mp3, PPro5 imported them
and after that the folder of the mp3 was
much bigger than before.
Example: i had a folder with 50 mp3 and after
conforming audio the folder was something like 2 or 3 GByte!
(I don´t remimber exact, i am at home and not in office)
But it was really extreme.
A workaround: import songs as wav, not as mp3. then the folder
stays smallGreating from Cologne
Claus-Peter Wolf
Brogan De paor
August 15, 2010 at 4:17 pmHi:
Thanks all for your responses. I’ll try dumping the renders.
Hurry up Adobe.
Brogan de Paor -
Jose Nunoz
August 16, 2010 at 12:19 pmWhew, I’m glad it’s a bug. I just had this issue happen last night where my project went from 49mb to 8GB! I hit save and went to bed and saw the 8gb premiere project this morning.
Hope fix comes out soon because I cant re-import the old – rebuilding my folder structure would take me hours and hours
I got the 8gb file back to 47mb by going to my scratch disks and deleting all previews. Upon opening the project premiere crashed, saved a recovery version and then that recovery version was back to 47mb and worked correctly.
Jon Barrie
August 16, 2010 at 1:03 pmPatience my fellow editors…patience. 😉
Jon Barrie
aJBprods
Clint Choate
August 4, 2011 at 4:29 pmSimilar issue… huge client, we have many many hours of HD footage with numerous high-res gfx etc. Working on project for months with no issues, yesterday it froze during a SAVE; lost an hour of work no biggie. Went to re-open and it says the file is corrupt. Went to open a Recovery in the Auto-Save (I auto-save every 5 min, 20 versions) and the Auto-Save Folder is over 70 gigs big!!!! Each back-up file is 3-4 gigs in size and takes 20+ minutes to load project; once project is loaded I get the Mac Spinning Wheel of Death when I try to click anywhere in the project window and it will not re-save to a new location without freezing (24 gigs of ram). My only solution thus far is to take 20 minutes to open a recovery file, and COPY everything in my sequence and PASTE it into a New Project, New Sequence, in a completely New Location. Only allowing me to copy 1 sequence at a time but I’ve recovered a small amount of my work.
Todd Kopriva
August 4, 2011 at 4:35 pmClint, have you installed the recent updates?
The “project bloating” bug was fixed in an update to Premiere Pro CS5.
Make sure that you have the most recent updates installed.
