Activity Forums Adobe Premiere Pro CS5 exporting using preview files – confusion
  • CS5 exporting using preview files – confusion
    Posted by Kris Koster on February 19, 2011 at 5:26 pm
    I attended the Broadcast Video Expo in London this week and Adobe had a huge stand showing off CS5.
    One thing the expert speaker (who works for Adobe) was telling us, is that you can use the preview files for export in CS5 without any quality loss with the benefit of a very fast export.
    I have two problems with that statement.
    First of all, I’ve always thought that those preview files were okay for working drafts, but were not for final output. But a member of the audience asked him, ‘When is it not good to use the preview files?’ and the Adobe guy said none that he could think of. So now I’m confused.
    The 2nd problem I have is that when I did try to export with the ‘use preview files’ checked (this is in CS5), it didn’t take the few seconds the Adobe guy was craving on about. In fact it took just as long as it did when I was building previews on the timeline.
    Please help my confusion! When is it okay to use those preview files for export (I export a lot using H.264 for web upload to Vimeo).
    Is it worth keeping previews on the timeline as I go along and then use them for my final export to H.264?
    https://kriskoster.com
    Jessica Vecchione replied 14 years ago 8 Members · 9 Replies
  • 9 Replies
  • Keith Moreau
    February 19, 2011 at 7:57 pm
    At least in my experience with a 8 Core Mac Pro with an Nvidia Quadro 4000 and 24GB of RAM there is no difference in export/encoding using the ‘use preview files’ option when exporting. In fact for me exporting is almost unusably slow except for the setting which using the sequence settings, in which case for me it’s about 2x of realtime. This may be partially because I’m doing multicam with very long files and 3-4 tracks at a time.
    My pretty fast workflow is to use Prores LT as the timeline format, the export using the sequence settings to a prores file. This takes about twice as long as realtime and can create a huge ‘master’ file. Then I can use Media encoder or various Quicktime encoders to produce my final output. The time taken for this workflow is about 3-4 times the length of the sequence. Not the fastest but I can live with it. Media encoder is pretty fast if it has a Prores file as the master.
    I’m not sure if the encoding performance is different it Windows or not. I have’t heard much about encoding times anywhere other than my threads.
    That being said, as a current and former FCP user PPRo saves me a bunch of time in the workflow, other than this point so it’s worth it to me. If anybody has advice about how to speed up encoding please feel free to provide advice.
  • Ann Bens
    February 20, 2011 at 1:07 am
    General advice is: do not use preview files they are of lesser quality.
  • Tim Kolb
    February 20, 2011 at 4:28 am
    I answered your original post that you tagged onto a 3 month old thread:
    https://forums.creativecow.net/readpost/3/909582
    TimK,
    Director, Consultant
    Kolb Productions,
  • Jon Barrie
    February 20, 2011 at 5:13 am
    I’d be interested to know if your workflow overall time to export to a single ProRes file is and the encode that master file to other is any quicker than just sending the export directly to AME and exporting to your formats immediately?
    You can duplicate the export queue to setup multiple export types. It will save you a massive amount of hard drive space. Exporting to a separate drive from OS and media can make a difference too.
    Cheers, JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Keith Moreau
    February 20, 2011 at 5:46 am
    This is a reply to Jon:
    Especially when downrezzing, it’s like 6-10 times the length of the sequence to use the file directly from PPRo Project to Media Encoder, and it takes that long for every instance of the file, so if I wanted to make, say a 270 (ipod-sized) encode, and a 480P (dvd sized) and 720P (AppleTV/iPad Sized) it could take 30 times the length of the original sequence. If I just make one master 1080p file that takes about 2x, then each encode is about 1 -2x, so this way saves me a lot of time. If I can just do one or 2 encodes overnight, I don’t care, however, because of strange artifacting in chroma-key’ed material in the downrezzed encodes I don’t trust it much so if I need it to be done I’ll just output the full rez prores. I can also inspect it a lot better than in PPro when it’s output at full rez and rendered.
    Maybe other’s experience is better, and believe me I’d like mine to be but it’s not so I just have to make it work as best as possible for me. Again if you have further suggestions please let me know. I could try using separate media but I don’t’ think that’s the bottleneck, but who knows. I just upgraded to a SSD boot system and things at least cosmetically are really speedy, maybe this will help PPro encoding. Thanks for your interest.
  • Todd Kopriva
    February 21, 2011 at 5:02 am
    I’ll quote myself from a recent article about rendering in Premiere Pro:
    “Note: Rendering of previews is only for preview purposes. Preview files will not be used for final output unless you have Use Previews option checked on output—–which you should not use except in the case of rough previews. Using preview files for final output will in almost all cases cause a decrease in quality. It can speed things up in some cases, so it may be useful for creating a rough preview in less time.”
    This advice comes from the people who wrote the code, too. When I first wrote that paragraph, one of the software engineers asked me to make it even stronger.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Kris Koster
    February 22, 2011 at 2:41 pm
    Thanks very much for clearing that up.
    I didn’t mishear what the guy from Adobe said at the London BVE Adobe stand last week. It surprised me because I always thought that using previews for output are for rough previews only.
    When he said he couldn’t think of any reason not to use the rendered previews for final output I was actually considering changing my workflow!
    I just assumed something had changed in CS5, which is why I questioned it here.
    Thanks again,
  • Pierre Conti
    November 16, 2011 at 8:05 am
    So why state in the same article that preview will be full quality (as render are NOT full quality?
    green: This segment of the sequence has a rendered preview file associated with it. Playback will play using the rendered preview file. Playback at full quality is certain to be in real time.
    premiere pro is a mess in my opinion. Exporting a small timeline can take ridiculous amount of time even though you don’t apply effect. I find it nerve racking not being able to export a timeline at 100% of its quality of its native codec in just a click.
  • Jessica Vecchione
    September 15, 2012 at 1:49 pm
    Is this still true….? I’m using CS5, mercury playback?
    Thanks.
