Activity Forums Adobe Premiere Pro CS5 — exporting still frame sequence
  • CS5 — exporting still frame sequence
    Posted by Jerel Peterson on October 9, 2010 at 6:41 pm
    I’ve fallen behind in Premiere over the past few years. I just got CS5 and I can’t figure out how to export a sequence of still frames. I can do it in CS3, but I can only get one frame saved when I try it in CS5.
    I’m going to: File | Export | Media. Select TIFF as the format, and set source range to Entire Clip.
    I’ve got the Teacher version, so I don’t have a manual. I found an on-line help page that says to select ‘Export as Sequence’, but I don’t see that any place.
    Brenda Garcia replied 11 years, 11 months ago 3 Members · 3 Replies
  • Vince Becquiot
    October 10, 2010 at 3:27 am
    Hi Jerel,
    Select tiff in export format drop menu(If that’s the format you are after) and in your video settings, check export as sequence.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jerel Peterson
    October 10, 2010 at 11:45 pm
    Thanks. I never bothered to check (and probably didn’t even notice) the Video tab in the middle of the screen.
  • Brenda Garcia
    October 7, 2014 at 12:20 am
    ah!million thanks!
