Activity › Forums › Adobe After Effects › CS5 export problem
Brett Spiegel
July 5, 2010 at 5:44 pmHi Kevin,
No I have no idea what is going on. I tried a couple of other things but no dice. The only thing I can think of is a quicktime to 64bit issue. It is extremely annoying because I have to export as tiff’s to make it work. As you know they are very large so when I am doing multiple versions it takes up a lot of room.
Brett
Brett Spiegel
http://www.brettspiegeleditor.com -
Gerd Guegel
July 13, 2010 at 10:02 pmI had the same problem. Everything else than qt worked fine, with qt you couldn’t even change the settings (small windows poped up and disappeared in a fraction of a second).
This was a new setup, fresh OS (snow leopard, QT7 installed as well), fresh CS5 install, 8-core….
Even new scene with standard setting couldn’t render out in Quicktime.Did some testing today and found the solution. The problem on my system is Optical Flare by videocopilot. If you initialize it once, afx won’t be able to render out to quicktime. At least this is the case with CS5 on Snow leopard.
What to do….:
Remove all the optical flare plug-ins from your scenery and save.
Go to User/Library/preferences/adobe/After Effects and delete all prefs.
Start afx and it will be able to render out qt as expected.BUT, if you open/active optical flare ONCE, you will have the same problem again. If you need to use it, render out in e.g. Tiffs. After that, quit afx, delete prefs….and you will be able to render qt again (but not if you open an optical flares accessing scene.
hope that helps.
