Activity Forums Adobe Premiere Pro cs5 export bigger then cs4
  • cs5 export bigger then cs4
    Posted by Dan Roth on February 9, 2011 at 8:49 am
    just exported the same file from cs4 and cs5 using the same settings (see attached picture) and yet the cs4 final mov was around 46 MB and not the best quality whereas the cs5 final is around 640 MB and much better quality. WITH THE SAME SETTINGS. why is this?
    thanks
    dan
    Vince Becquiot replied 15 years, 6 months ago 3 Members · 2 Replies
  • Todd Kopriva
    February 9, 2011 at 9:55 pm
    Are you certain that the settings are the same. For example, your Quality setting at 100 makes sense to me for a rather large but high-quality file.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Vince Becquiot
    February 10, 2011 at 12:26 am
    And I noticed that you are exporting at 0.9 PAR. I would use square pixels instead and adjust the resolution accordingly.
    Also, try H.264 from Mainconcept instead of Apple’s. You can find it as H.264 in your export list. Start with a bit rate of 6 MB/s.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
