Activity › Forums › Adobe After Effects › CS5: CTI doesn’t move when caps lock on.
Posted by John Stanowski on June 29, 2010 at 12:16 pmWith After Effects CS4 you could hit the Caps Lock key to preview audio in a comp with a ram preview without letting any video render. The CTI used to move along while you did this. I was able to get visual feedback as to where I needed to add my markers to keep things in sync with voiceovers.
I’m making my spots for the first time in CS5 and to my horror the CTI isn’t moving. Is something wrong here, or is this supposed to be an improvement???
Anyone know?
John Stanowski replied 16 years, 2 months ago 4 Members · 8 Replies -
Kevin Camp
June 29, 2010 at 12:19 pmtry hitting the decimal in the numbers pad to do an audio preview. (i don’t have cs5, but this is how i’ve always done audio previews, if it doesn’t work, then there really is something wrong with your cs5).
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
John Stanowski
June 29, 2010 at 12:20 pmAwesome, thanks! Works great!
2009 Intel MacPro
8 cores
16gig ram
Snow Leopard (up-to-date)
Adobe Master Collection CS4 -
John Stanowski
June 29, 2010 at 12:21 pmP.S. That was the quickest help I ever got from a forum.
2009 Intel MacPro
8 cores
16gig ram
Kevin Camp
June 29, 2010 at 12:37 pmit’s all in the timing…
and i’m filling in an embarrassingly easy job while a co-worker’s out on vacation… the catch is the shift starts at 4am, and i need to do something to stay awake.
glad i could help.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Steve Roberts
June 29, 2010 at 12:45 pmHmm … maybe this is actually a feature: with Caps Lock on, nothing updates, even the UI. There have been times where a sort of “kill switch” was needed, if I recall.
Todd might be able to confirm this.
Hey Kevin, give me your number. I’ll call you every five minutes to wake you up. 😉
Kevin Camp
June 29, 2010 at 1:02 pmhey steve,
luckily the coffee is free, so i have an endless supply of caffeine
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Todd Kopriva
June 30, 2010 at 8:22 amKevin works down the road from me, so I can confirm that he has plenty of good coffee nearby.
Regarding what updates with the Caps Lock on: Caps Lock prevents the rendering of any video content for preview in the viewer panels. It shouldn’t prevent the rendering of audio content.
I just tried RAM preview with CS5 on Windows 7 and Vista, and the audio played fine with Caps Lock on. The CTI moved as normal. If you’re experiencing unexpected behavior, file a bug.
That said (as others have said) you have other means for previewing audio only. See “Preview video and audio”.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
John Stanowski
June 30, 2010 at 11:05 amI just tried it again and I’m home right now. Same thing happened. Pressing 0 with caps lock on does play the audio, but the CTI doesn’t move. I will file a bug report. Maybe it’s a mac thing.
I’ll use the decimal key from now on.2009 Intel MacPro
8 cores
16gig ram
