Activity Forums Adobe Premiere Pro CS5 crashes at start and losses audio
  • CS5 crashes at start and losses audio
    Posted by Guille Ibanez on October 17, 2011 at 12:47 pm
    Hi everyone,
    Sorry if this has been covered before but I couldn’t find any answer on my search.
    I have a problem which has been haunting me for a good couple of months and I’m really fed up now. Two months ago I started using Plural eyes to sync my different video and audio files into the timeline. I believe Plural eyes syncs your clips and converts stereo audio into dual mono clips. Everything fine so far, I editing for hours, save my project and the next time i open it…..voila! Premieres crashes when loading and says: ‘Premiere has encountered an error [….SetClipMasterClip.cpp -2802]’ (see image below)
    This means that the project becomes unusable as i can’t open it at all. Great. The only workaround is to import the entire project into a blank project……and this would be a great solution only if Premiere hadn’t lost every single audio in the timeline. And that means every single one (see image below)
    The only workaround is to reconstruct every single piece of audio every time or to leave the computer on forever and ever.
    Needless to say that this is a v serious bug which i don’t believe is related to Plural eyes but Premiere mishandling files. Has anyone found this problem before? I can’t really keep on working like this and i’m even considering switching NLE as this is incredibly frustrating.
    thanks in advance
    Guille Ibanez replied 14 years, 11 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    October 18, 2011 at 1:36 am
    Actually, I’m pretty sure it is related to Plural Eyes. You may want to submit Adobe and Singular Software a bug report as I recall it happened to me when Plural Eyes for Premiere first came out.
    1. With Premiere closed, do this:
    Go to C:\Users\YOURNAME\AppData\Roaming\Adobe\Common\Media Cache
    and C:\Users\YOURNAME\AppData\Roaming\Adobe\Common\Media Cache Files
    and deleting all the files in both folders. These are just cache files and conformed audio/video and can be deleted safely. This should force Premiere Pro to re-conform your work files once it reopens.
    2. Start Premiere, open a new project and import the seemly corrupted project into it like you’ve done before.
    If memory serves me right, this should work.
    – Angelo Lorenzo
    An iPhone 4S tribute to Steve Jobs
    https://FilmsFor.Us Sell your film and connect with your audience
  • Guille Ibanez
    October 19, 2011 at 9:40 am
    thanks for replying Angelo.
    I tried your suggestion when i first had the problem as pointed out by PluralEyes support. it didn’t work.
    However I’ve been doing a bit of research and I just discovered a blog entry by Adobe announcing the PremierePro CS5.5.1 update. One of the points at the bug fixes section mentions:
    “Projects created by importing Final Cut Pro XML projects that contain multiple mono clips would lose some audio when the project was closed and reopened.”
    https://blogs.adobe.com/premiereprotraining
    It doesn’t mention the crash but I think this is exactly what my problem is as you have to import the Final Cut Pro XML file generated by Plural Eyes.
    I guess the bad news is, I can only get rid of the problem by paying the upgrade to CS5.5. Damn
    thanks
