Activity Forums Adobe Premiere Pro CS5 and ProRes 422
  • CS5 and ProRes 422
    Posted by Pau Masó on May 14, 2013 at 3:53 pm
    Hello.
    I need your help!
    I’ve edited a video on a Mac on Premiere CS5 and now need a ProRes 422 file for delivery. I can’t find the option even though I have Final Cut Pro installed.
    Is exporting an MP4 file and then converting it into ProRess 422 an option, or I’m losing quality?
    Additionally, XML does not work.
    Thank you in adavnce!
    Pau Masó replied 13 years, 2 months ago 4 Members · 11 Replies
  • 11 Replies
  • Kris Merkel
    May 14, 2013 at 4:28 pm
    In your export dialog choose quicktime as the format and custom as the preset, and under video codec choose Prores
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Pau Masó
    May 14, 2013 at 4:32 pm
    Thank you Kris,
    I don’t have the custom option! Also, for FCP, it’s the trial version. Should I simply buy it… still, if in Premiere I don’t have custom, what am I supposed to do?
    Thank you,
  • Ryan Holmes
    May 14, 2013 at 4:51 pm
    So you have FCPX as a trial version?
    That probably won’t get you the goods. The least expensive option is to buy Compressor from the App Store, which I believe still gets you the ProRes codec pack. If you want FCPX though, don’t let me stop you! 😉
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Pau Masó
    May 14, 2013 at 4:55 pm
    Thanks Ryan,
    But does installing the compressor work for Premiere, because it seems like it is a tool for FCP. Is FCP worth it? I may just buy it, but I have to make sure that CS5 will give me the ProRes 422 export option.
    Thanks again,
  • Ryan Holmes
    May 14, 2013 at 5:04 pm
    Compressor doesn’t integrate with Premiere (meaning you can’t directly export from Premiere into Compressor). You’re just buying Compressor so you can get your hands on the ProRes codec. FCPX is $300 and Compressor is $50. If you just want the ProRes codec package then Compressor is your cheapest option. If you want a different NLE, then FCPX it is.
    Ryan Holmes
    @CutColorPost
  • Kris Merkel
    May 14, 2013 at 5:06 pm
    It’s been awhile since I have worked in CS5.5 I though the option to choose a custom preset was there but I could be mistaken.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Pau Masó
    May 15, 2013 at 12:09 am
    So the question is, If I install Compressor or Final Cut Pro, will Premiere show the Pro Res 422 option, or still not?
    Thank you,
  • Tim Kolb
    May 15, 2013 at 1:08 am
    Yes, if you install a software package that can write to Prores, that ability now exists in QuickTime and you can export from Premiere Pro…pick QuickTime format, and below in the video tab you’ll see the video codec (i think it usually defaults to DV), just go to that widget and change the target codec.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Pau Masó
    May 15, 2013 at 1:20 am
    Thanks Tim,
    One more question. If I currently have Final Cut Pro X (Trailer), shouldn’t I be able to see the option as well for the trail period on CS5 (cause I don’t). Not sure if it’s cause I have to buy it. If so, the compressor will do then?
    Thanks again!
  • Tim Kolb
    May 15, 2013 at 2:51 am
    I don’t know how Apple does that…it s possible there is some limitation on the trial version of FCPX… If you can’t see it (it looked like you could set it up to export on your screen grab…), you may want to get compressor so you can get it done.
    TimK,
    Kolb Productions,
