Activity Forums Blackmagic Design CS5 and BMD sequence with XDcamEX 1080i50
  • CS5 and BMD sequence with XDcamEX 1080i50
    Posted by Sebastian Roeder on June 11, 2010 at 7:24 am
    Hi all,
    we are using the Decklink Studio 7.6.4 with CS 5.0.1 and had a closer look at the SDI out. When using a XDcamEX sequence with such footage (XDcamEX 35Mbit/s 1080i50) we realize certain field problems at the output. It’s strange and hard to describe but when you are dealing with high color saturated footage which is moving fast you can see some strange behavior of the chrominance – it is jittering and looks like the chroma has the wrong field order and fields are doubled somehow. When you stop and look at one still field you can see that every second line in one fild has no color at all.
    Can anyone reproduce this issue?
    Regards
    Sebastian
    PPro 5.0.1 – Win7 Pro 64bit – Tyan Tempest i5400XT (S5396) – 8 GB RAM – Geforce GTX 470
    Sebastian Roeder replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
