Activity Forums Adobe After Effects CS5 After Effects audio problem
  • CS5 After Effects audio problem
    Posted by Romel Mebane on September 6, 2010 at 4:56 pm
    I having problems with a audio file i imported into after effects. I created a project so i imported a audio file to it.when i render the video when its done there is no audio. Can some one help me.
    Romel Mebane replied 16 years ago 3 Members · 4 Replies
  • Todd Kopriva
    September 6, 2010 at 7:53 pm
    Make sure that the Audio Output option is checked in your output module settings.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Romel Mebane
    September 6, 2010 at 11:23 pm
    Thanks for answering my post. Your advice helped me out.I went to the output module and changed the settings.But now i came across another problem. Now the audio is sounding funny, it sounds like its slowing down, then it sounds like its speeding up,then it slows down again.Can you help me on this todd?
  • Walter Soyka
    September 7, 2010 at 1:17 am
    You’ll need to supply some more information about your project. What version of After Effects are you using? What OS? What is the container and codec your footage is in?
    If you are running After Effects CS5, and you’re using AIFF media, be sure to install the recent 10.0.1 update. If you’re running After Effects CS4 or earlier, and you’re using temporally-compressed audio like MP3 or M4A, you should transcode it to a WAV or AIFF instead.
    Walter Soyka
  • Romel Mebane
    September 8, 2010 at 11:56 pm
    Thanks for responding but i resolved my problem. i went to the output module and correct the settings in the audio output.
