Activity Forums Adobe After Effects (CS5) AE Render Performance VERY POOR
  • (CS5) AE Render Performance VERY POOR
    Posted by Phil Smith on May 19, 2010 at 10:05 pm
    Hello everyone. I’m going to make this as short and sweet as I can. Thanks in advance for any help.
    – System: Mac Pro 8-core Nehalem (2.66GHz), Snow Leopard 10.6.3, ATI Radeon HD 4870
    – RAM: 16GB
    – Hard Drives: 3TB SATA RAID Internal (caches stored here), 16TB Fiber Channel SAN (render output here)
    – AE Settings: Disk Cache Enabled (~10GB on internal RAID); 13GB RAM allocated to AE, 3GB to other apps; Render Multiple Frames Simultaneously enabled, no CPU’s reserved for other applications.
    – Project: 720×486 comp, standard DV settings, 14 seconds total; but ONLY first 4 seconds has animation, the rest is still frame. There are only text and particle layers, not even a background.
    – Behavior: After setting up the project and clicking “Render”, the render will get through the first 11 frames, then STOP. It holds there for about a minute, and then renders the last of the frames VERY SLOWLY. It finally completed the render after 6 minutes, 23 seconds.
    This SAME file rendered in CS4 on a lesser horsepower machine in 30 seconds. I’m stumped.
    Phil Smith replied 16 years, 4 months ago 2 Members · 2 Replies
  • Todd Kopriva
    May 20, 2010 at 1:07 am
    That is a huge red flag.
    See this page:
    https://blogs.adobe.com/toddkopriva/2010/03/performance-tip-dont-oversched.html
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Phil Smith
    May 20, 2010 at 6:41 pm
    Thank you for the tip!
    However, after trying 8, 6, 4, 2 processors and then even shutting off multiprocessing, I still get the same result.
    Maybe it’s a comp issue? I’ll see if I have enough time to rebuild this whole thing in CS5-AE, unless you have another suggestion?
    Really appreciate your time!
    -PJ
