Activity Forums Adobe After Effects CS5 – Adjusment layer – 3D Space
  • CS5 – Adjusment layer – 3D Space
    Posted by David Biederbeck on February 16, 2011 at 10:44 pm
    Just got cs5. I had a glitch when adding an adjustment layer with curves on it. It made all my 3d layers appear 2d.
    I precomped, tried again, same thing.
    I took the adjustment layer out of the precomp and into my main, left the layers in the precomp, and it worked.
    Is this new, to cs5, any reasons if so? Or is it just something I haven’t run into before? because I normal comp everything.
    Darby Edelen replied 15 years, 6 months ago 2 Members · 2 Replies
  • David Biederbeck
    February 16, 2011 at 11:01 pm
    Thanks Dave. I just updated. Thanks.
  • Darby Edelen
    February 19, 2011 at 4:35 am
    To be clear, this happens when you add any adjustment layer at all, whether it’s 2D, 3D and no matter where it is in the layer stack?
    2D Adjustment layers have always ‘broken’ 3D space to some degree (which is actually quite helpful once you learn to expect it).
    Darby Edelen
