Activity Forums Adobe Premiere Pro CS4 Updated Encoder Update Error via PPro
  • CS4 Updated Encoder Update Error via PPro
    Posted by Barbara Lloyd on January 4, 2009 at 11:05 pm
    If you happen to run your Adobe Updater from Premiere Pro and you get the following error for Adobe Media Encoder you will want to run the Adobe Updater from Encore CS4 instead.
    “Adobe Media Encoder CS4 Exporter 1.0.1, Adobe Media Encoder CS4 Importer 1.0.1, Adobe Media Encoder CS4 1.0.1, Failed to install.”
    I opened a case with Adobe and that is the solution they gave me and it did work. I did also submit the following suggestion, which they did not seem to acknowledge:
    “I did look for an Stand-Alone ‘Updater’ in the Windows Program Menu. That would have been very useful.”
    Barbara Lloyd
    Cinematographer & Producer
    Stella Luna Productions
    https://www.StellaLunaProductions.com
    https://www.vimeo.com/user994896/videos
    Barbara Lloyd replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
