Activity Forums Adobe Premiere Pro CS4 second monitor
  • CS4 second monitor
    Posted by Stephen Lesser on March 31, 2009 at 5:32 am
    Hello, I just upgraded to Premiere Pro CS4 and my second monitor (extended desktop) has since been unable to show video. I extend the interface across the two screens and everything works except that the source and program window will not show anything if it is in the second monitor (but will work fine in the first main monitor). The second monitor will only show a gray rectangle in the source and program window. The two monitors worked fine in 2.0. Is this a known issue with CS4, or is there some fix for this? Thanks!
    My machine:
    Windows XP SP3
    Intel Core 2 Duo 2.0 Ghz
    2 Gigs RAM
    GeForce Go 7700
    Eddie Lotter replied 17 years, 4 months ago 4 Members · 5 Replies
  • Tim Kolb
    March 31, 2009 at 5:54 pm
    Did it work with CS3 or some other NLE?
    TimK,
    Director, Consultant
    Kolb Productions,
  • Stephen Lesser
    March 31, 2009 at 8:40 pm
    It worked fine in Premiere Pro 2.0, I never tried it with CS3.
  • Edward Roberts
    April 1, 2009 at 3:14 pm
    Am I correct in assuming this is a notebook? I won’t say that it won’t work, however there are many issues involved with getting video and dual notebook monitor setups to work. First to consider is the that video RAM is shared. The other is to be careful to use the correct video drivers for that notebook. I have found that in some cases the video chip manufacturers drivers work better than the notebook makers drivers and in other cases I have seen the reverse is true.
    I would try to change drivers first. If no joy, than you may want to consider a fresh OS install.
    Edward Roberts
    Micro Media
    Greer, SC 29651
    micmedsales1@micmed.com
    https://www.micmed.com
    https://www.thecablestation.com
  • Stephen Lesser
    April 8, 2009 at 3:51 am
    I found that I can use the dual monitors when my NVIDIA Control Panel is set to Horizontal Span instead of Dual View. Strange, because everything else works when spanned across both screens in Dual View. Well, at least it works in some configuration…
  • Eddie Lotter
    April 8, 2009 at 2:15 pm
    It is rather tricky. I try to document people’s successes here.
    Cheers
    Eddie
