Activity Forums Adobe Premiere Pro CS4 Rendering suddenly takes 4 times longer
  • CS4 Rendering suddenly takes 4 times longer
    Posted by Clay Miller on October 8, 2012 at 11:53 pm
    Been using Pro CS4 for several years. Rendering has never been a problem for me. Now all of the sudden projects that may have taken 6-8 hours to rendering are taking 20 hours or more! Does anybody have a clue how that might suddenly be happening?
    I am rendering to Encore for a DVD.
    The only thing I have done different recently is that I added one of my owned additional used hard drives into the machine, but it is not used in any way with these projects. But just to eliminate that as a problem, I have disconnected it completely and I still have the same problem.
    Any ideas?
    Mike Wong replied 13 years, 10 months ago 2 Members · 1 Reply
  • Mike Wong
    October 30, 2012 at 6:29 am
    I had a similar problem with an old hard drive. If that’s not the problem then check to see you have enough space on your hd, processes running in the background (run msconfig and restart pc with only the basic services running and render to see if it improves the time), check for viruses or malware, overheated CPU, slow fan..defrag your drive and try this benchmark software. https://ppbm4.com/
    Mike Wong | Zerosum | https://www.zerosum.ca
