Activity › Forums › Adobe After Effects › CS4 rendering issue
  • CS4 rendering issue
    Posted by David Roffman on December 21, 2011 at 5:26 pm
    I have been working on my demo reel and now it skips rendering. The final outcome is a .mov that hesitates and then skips over a large portion of the 1:30.
    I am using a MacPro 2006-2007 (1,1 which only has the dual core)
    Am I being unrealistic in thinking that I can accomplish rendering my demo reel on it?
    I upgraded my RAM to 15G, but still won’t work.
    HELP!!
    Michael Szalapski replied 14 years, 9 months ago 3 Members · 5 Replies
  • Steve Blacker
    December 21, 2011 at 6:17 pm
    What sort of file are you trying to render to? What resolution?
    A lack of planning on your part does not constitute an emergency on mine.
  • Michael Szalapski
    December 21, 2011 at 10:02 pm
    To back up what Dave said, read this entry on Adobe’s site: [link]
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • David Roffman
    December 22, 2011 at 5:42 pm
    Thanks Dave — much appreciated
    I’m about to us Adobe Media Encoder as per your suggestion, but I’m a little confused as to the proper settings to use once inside AME. For the Format I’m using h.264, but what should I use for the preset? It defaults to NTSC DV High Quality.
    Also I’m having difficulties discerning the method of output. Under Export Settings it shows my source as 960×540 with an output of 720 x 480. Is that what h.264 does?
    I’ve been using Compressor up to this point, but now in my quest to switch to an all Adobe workflow, I’d really like to start using Adobe Media Encoder.
    Thanks in advance
  • David Roffman
    December 22, 2011 at 6:17 pm
    I’m following the link now – thanks – It’s very helpful – great link! (leading to other great resources)
  • Michael Szalapski
    December 22, 2011 at 7:39 pm
    You can specify anything you want as far as H.264 goes (within the limits of the codec, of course).
    You’re going to want to change the frame size to match your source (unless you’re shrinking it for some reason and/or if you’re changing the pixel aspect ratio). You’ll also want to play with the data rate for the video and the data rate for the audio. This is where the dance begins – image quality vs. file size: GO! Don’t forget to hit the radio button for two encoding passes instead of one.
    – The Great Szalam
