Activity Forums Adobe After Effects CS4 – Render or export to MWV format
  • CS4 – Render or export to MWV format
    Posted by Joakim Werner on March 16, 2009 at 9:45 am
    I would really like some help. How do you render or export so you get a MWV format in AE CS4? I am a mac user and I cann’t find any settings including MWV. Do I have to do this through a PC?
    Can I create any results in other programs such as Premier or Adobe Media Encoder?
    Any solution is much appreciated. Thanks!
    Joakim Werner replied 17 years, 5 months ago 3 Members · 4 Replies
  • Kevin Camp
    March 16, 2009 at 2:36 pm
    you should be able to ‘export’ a wmv from ae… open your comp, then choose file>export>windows media…
    i can’t vouch for the quality of a wmv from ae. if it doesn’t look good, you may want to inquire about a wmv utility for mac on the compression techniques forum, or optimal settings for the wmv export in ae (it does have a setting for 2-pass vbr, which surprises me a bit, since ae doesn’t usually handle 2-pass encoding, but 2-pass vbr is usually the way to go…)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Steve Roberts
    March 16, 2009 at 4:52 pm
    You might need Flip4Mac. Or you could make an Animation-compressed movie, then use QT Pro to Export to Windows Media.
  • Kevin Camp
    March 16, 2009 at 4:57 pm
    [steve Roberts] “You might need Flip4Mac.”
    ah yes, i just noticed that my wmv export is part of flip4mac… sorry if i had you pulling your hair out looking for that export option…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Joakim Werner
    March 17, 2009 at 10:17 am
    I just realized that I typed in the wrong file name. It is WMV (windows media video). Sorry for the mess up. I know that it was possible in CS3, have they taken away this function or changed it to a better format?
