CS4 & PS Layer Styles
I’ve set up a PSD with two layers, each containing a Pattern Overlay layer style. I import it into After Effects CS4 as a Composition with Editable Layer Styles. Then, without any expressions or keyframes, the top layer with the Pattern Overlay moves from the center to upper-left corner in about 5 seconds. The bottom layer style does the same thing, although not as drastic. The layers themselves do not move. Is there a bug with Editable Layer Styles in CS4?
