Activity Forums Adobe Premiere Pro CS4 Prem Pro. Audio out of sync when capturing.
  • CS4 Prem Pro. Audio out of sync when capturing.
    Posted by Lisa Frey on March 8, 2010 at 12:26 am
    I am capturing mini dv’s from a canon Gl camera into Prem pro on my MAC.
    All tapes are now being captured out of sync. This just happened out of the blue, nothing changed??
    Now every tape i try and capture i am getting this issue.
    Can anyone help.
    Lisa
    Damon Muma replied 16 years, 5 months ago 3 Members · 6 Replies
  • Mike Velte
    March 8, 2010 at 11:21 am
    The most likely cause is dropped frames on capture, leaving audio longer than video. Premiere advises on dropped frames at the top of the capture window during capture. Hardware issues are often the cause, like a too full capture drive, but conflicting software issues can also cause this, like virus scanner.
  • Lisa Frey
    March 10, 2010 at 3:40 am
    Thank you for responding, my hard drive is pretty full, so i will get rid of some footage and see if that helps.
    Thanks again.
  • Mike Velte
    March 10, 2010 at 11:22 am
    Defragment the drive prior to capture/
  • Lisa Frey
    March 10, 2010 at 2:23 pm
    OK, i need to do that, not sure how though?
    I just captured more footage and when it is being captured in capture window, it is all in sync, however when i lay on timeline it goes out of sync. I called adobe before i posted this message, i didn’t have 2 hrs spare to spend on the phone with them, but reinstalled PP and checked my capturing device against the software and all was good, but for some reason it goes out of sync on timelime. Hmmm..do you have any more ideas?
    Thanks again
  • Mike Velte
    March 11, 2010 at 12:10 pm
    Does the sample rate of your source audio (32 or 48 Hz) match your sequence setting?
  • Damon Muma
    April 24, 2010 at 4:32 am
    I am having the same issues with audio… Premiere reports one dropped frame, but that’s not enough to make as much of a difference as I’m seeing here… or is it? I’m pretty sure the dropped frame is a false reading cause there’s one right at the beginning.
    I think blaming defragmented harddrives and things is a bit premature these days.. if you have no other major apps running and a good system Premiere should be able to capture.
