Activity › Forums › Adobe After Effects › CS4 OpenGL crashes render
  • CS4 OpenGL crashes render
    Posted by William Philbin on March 9, 2009 at 8:42 pm
    I am currently using the Cartoon plug-in for an effect in CS4 on my Mac 2 x 2.8 GHz Quad_Core with 10 GB of RAAM. When I change the resolution to Full or I try to render a dialogue box comes on saying “After Effects warning: A problem occurred when processing OpenGL commands.”
    I turned off OpenGL in my preferences and when that didn’t work I took out the OpenGL plugin from my plugins folder and stuck it on my desktop.
    Has anyone come across this problem?
    Thanks.
    William Philbin replied 17 years, 6 months ago 3 Members · 5 Replies
  • William Philbin
    March 9, 2009 at 8:59 pm
    Yeah. In my rendering settings I made sure the ‘Use OpenGL’ box wasn’t checked and also in Preferences I made sure it was off and just in case I made sure it was off in my ‘Fast Preview’ box in my Composition window. After that didn’t work – I actually took the OpenGL Plugin out of the Plugin folder. I restarted the CS4 but after doing all that – and it still says ‘A problem occurred when processing OpenGL commands.”
  • Kevin Camp
    March 9, 2009 at 9:10 pm
    in the advanced settings in the effect, disable opengl…. ae probably had a problem with the opengl commands, because you had disabled opengl (… and i’m not saying you should enable opengl)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • William Philbin
    March 9, 2009 at 9:54 pm
    That was the problem! Thank you.
  • Darby Edelen
    March 10, 2009 at 9:02 am
    Out of curiosity, what kind of GPU do you have and what are your settings under “OpenGL Info…” in your Previews preference pane?
    Darby Edelen
  • William Philbin
    March 11, 2009 at 12:33 am
    My settings were at 245MB and everything category said it was supported and I was using the adaptive resolution at 1/4 — I think my GPU is an ATI Radeon HD 2600 XT.
