CS4 multicam sequence shows only 1 of 3 clips
I have a project that I have been working on for a month and am now having an issue with the multicamera sequence within the project. I am using a 3 camera multi camera sequence and have cut 1 hr. and 30 min. worth of video between all three cameras. I opened the project today and found that despite all my cuts on the multicamera nested sequence I can only see 1 camera in the preview window. All the multicamera clips used to read MC1, MC2 or MC3 and now they do not. They are now labeled as the raw footage sequence from which I created the multicamera nested sequence. When I right click on the clips in the nested sequence they are not multicamera enabled and if I choose to multicamera enable a single clip, all the clips on the entire timeline change to another camera but once again it is the same camera all the way through the timeline. What should I do?
I have tried creating a new project and importing the old project(the project where I am experiencing the problem) into it but there was no change. I also tried right clicking on the cameras in the project panel and replacing them with themselves(the acutal files on my hard drive). Again there was no change. I tried turning on and off the video and audio layers on my raw footage timeline from which I created the multicamera nested sequence and the changes I made were reflected in the clips on the nested sequence. For example, when I turned off all video I could not see any video on the nested sequence. This leads me to believe that they are still linked somehow but the project is still not working properly. I’m using a Matrox Axio LE running on Vista 64bit using Premiere Pro CS4.
Thank you!
