Activity Forums Adobe After Effects CS4 mac pro crashes on auto-save
  • CS4 mac pro crashes on auto-save
    Posted by Chris Borjis on July 17, 2009 at 4:27 pm
    Having an odd crash occur with After Effects Cs4 MAC with the 9.02 update.
    working along just fine, then the auto-save comes up and I get the spinning beach ball
    forever.
    auto-save is disabled and yet it still does this.
    I have 2 different machines, they both have this problem.
    The systems are nehalems with 16gb of ram so i know its not lack of cpu or memory.
    Anyone?
    David Cabestany replied 13 years, 11 months ago 7 Members · 6 Replies
  • John Davidson
    August 13, 2009 at 4:37 am
    This is happening with me, too. Very frustrating! Did you figure it out?
  • Iain Frengley
    October 16, 2009 at 1:12 am
    I was having the same problem – What worked for me was turning on the ‘allow scripts to write files & access network’ option in the after effects general preferences menu. Might be the cause if anyone else out there is running scripts & having the same problem…..
  • Simen Grankel
    October 26, 2009 at 5:32 pm
    Was called to help a friend who had this problem – found this thread – and Iain’s solution seems to do the trick!
  • Chris Garcia
    February 17, 2010 at 10:35 pm
    I hope Lain’s fix works. I just lost an hour of work. Thanks Adobe!
  • Matthew Keane
    February 25, 2011 at 2:05 pm
    Turning on that scripts preference worked for me too, on a Mac Pro with CS4 (AE 9.0.3.2) – Thanks for the tip!
    Matthew
  • David Cabestany
    September 25, 2012 at 8:53 pm
    I’m on CS6, I have the same issue, both with Autosave disabled and Script access enabled.
