Activity Forums Adobe Premiere Pro CS4 – Losing My Widescreen During Encode
  • CS4 – Losing My Widescreen During Encode
    Posted by Keith Emroll on April 26, 2011 at 10:53 pm
    I have a Premiere Project with the following setup:
    Footage was captured as 720 X 480 (1.2121).
    Sequences are set with the DV – NTSC Widescreen 48kHZ built-in preset, which matches what the footage is.
    I was somehow able to encode a Quicktime MOV file that preserved the original aspect ratio. I believe I did it by selecting the Quicktime format and the DV NTSC Widescreen preset when I went into export the media. However, when I do that now, having not changed a thing in the Premiere project, the final video comes out looking like a pan-and-scan movie (or like the footage from a normal 720 X 480 – 0.9091 setting).
    Can anyone help me figure out how to get the encoder settings so that I can render this with the aspect ratio preserved?
    Keith
    Keith Emroll replied 15 years, 4 months ago 4 Members · 6 Replies
  • Jeff Greenberg
    April 27, 2011 at 3:59 am
    I’m using 5.5 (so I know it’s different…but…)
    when I hit the encoder, on the video tab, if I scroll down, I have an Aspect switch, which I set to widescreen. Sorry, I don’t have CS4 around….
    does that help at all?
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Jeff Pulera
    April 27, 2011 at 1:37 pm
    Hi Keith,
    For web or computer playback, export as 854×480 using 1.0 Pixel Aspect Ratio (square pixels). This will preserve the 16:9 aspect in any player, as most do not recognize non-square pixels.
    Jeff Pulera
    Safe Harbor Computers
  • Ann Bens
    April 27, 2011 at 6:00 pm
    QT is notorius in not reconizing the PAR.
    I would use the VLC player instead.
  • Keith Emroll
    April 27, 2011 at 9:32 pm
    Jeff,
    Worked like a charm! Thanks so much!
    Keith
  • Keith Emroll
    April 27, 2011 at 9:33 pm
    Jeff,
    I have an encoding pre-set that is made for Widescreen, so I’m already working with that. Actually, I tried Jeff Pulera’s suggestion of changing to Square Pixels and it worked perfectly.
    Thanks for your help, though. I was getting really nervous because I couldn’t remember how I did it the first time!
    Keith
  • Keith Emroll
    Ann,
    When I did it the first time (which I can’t remember how I did it!), it played in Quicktime with no stretching. However, having a VLC player as another resource will be helpful in the future, I’m sure. Thanks for suggesting it!
    Keith
