Activity Forums Adobe Premiere Pro CS4 – Imported File Audio Weirdness
  • CS4 – Imported File Audio Weirdness
    Posted by Chuck Weatherall on May 3, 2010 at 9:20 pm
    An avi file is created in Premiere from a student project. The file plays just fine on the student’s PC. The file is then transferred via a flash drive to the professor’s laptop. The file plays just fine in VLC. When imported as mono, the file plays correctly in Premiere. If imported as “Same as File” it imports as a stereo file, the waveforms appear in the timeline, the meters bounce correctly, but no sound comes out during the head and tail. ??? Thanks.
    Chuck Weatherall replied 16 years, 4 months ago 2 Members · 2 Replies
  • Vince Becquiot
    May 3, 2010 at 9:23 pm
    What was the codec used for the export. Your best option is AVI with compression set to none.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Chuck Weatherall
    May 3, 2010 at 9:29 pm
    It’s all DV, all the way through the process.
    “Wherever you go, there you are.”
