Activity Forums Adobe Photoshop CS4 extended loosing frames?
  • CS4 extended loosing frames?
    Posted by Gary Jarvis on August 21, 2010 at 3:26 pm
    I seem to be loosing frames
    My process is;
    a) Import QT 264 in frames to layers.
    b) adding by duplication some of the layers which say gives me a total of 400
    c) converting layers to frames
    d) checking I have the correct # of frames
    e) play it through in animation
    f) exporting in QT
    g) re-importing for the sole purpose of confirming my layer/frame count
    h) I found that I now only have 320 frames/layers
    Can anyone explain why I am loosing frame/layers? Cos I am totally confused, I’m not sure whether it’s p/s or qt that’s causing my dilemma
    tks Gary
    Gary Jarvis replied 16 years ago 2 Members · 6 Replies
  • Richard Harrington
    August 21, 2010 at 3:50 pm
    Are you using PS extended?
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Gary Jarvis
    August 21, 2010 at 5:02 pm
    Yes Richard I’m using extended!
    The thing I am doing different here is I’m duplicating layers, it seemed much faster than duplicating a group then dragging them into place which I have done and it worked,
    I also am starting with less than 200 frames per clip this way I don’t exceed the 500 max.
    August 21, 2010 at 9:31 pm
    File > Open and just select the movie… don’t import frames
    If going to AE or Premiere… just save a PSD file (and keep movie in same folder)
  • Gary Jarvis
    August 21, 2010 at 11:03 pm
    Thanks for the response Richard,
    I actually tried in Ppr and was only allowed a max of 100 frames psd unless I did something wrong
    Gary
    August 22, 2010 at 12:13 am
    DO NOT IMPORT AS FRAMES
    File > Open the movie file
  • Gary Jarvis
    August 26, 2010 at 10:12 am
    Hey Richard you are 100%!
    The way it is working is, as you said “open clip” go to document settings and note frame setting and time, flatten into layers, convert to frame animation, add/subtract whatever frames one is going to dupe, convert back to timeline double check frame setting and time, adjust frame setting and/or time based on whether one added or subtracted, export as vid clip this is to double check the clip is seeing all frames if good or not cancel, make changes if necessary by adding/subtracting to time, select all, make frames from layers, play, export.
    Once again thanks
    Gary
