Activity Forums Adobe Premiere Pro CS4 – errors, crashes
  • CS4 – errors, crashes
    Posted by Wojciech Jastrzębski on August 28, 2010 at 11:53 pm
    Hello, I am getting problems with my Premiere – constant crashes and errors, here’s black bar that appears on a clip with Magic Bullet Looks (only when exporting to MPEG2). Source material – EX1r XDCAM.
    Soft – Master Collection CS4, updated, XP SP3, everything legal.
    Ggabyte GA-EP35-DS3L board, Quad Core 9550, RAM Kingston Hyper X 8 GB, graphics ASUS EN9500GT MG 512.
    Any ideas? I’m tired of these errors.
    Wojciech Jastrzębski replied 16 years ago 4 Members · 7 Replies
  • 7 Replies
  • Jon Barrie
    August 29, 2010 at 12:27 am
    Are you seeing the sane issue without the magic bullet effects?
    I recall there being a problem with the magic bullet third party software. Which is not an Adobe problem but magic bullet.
    Let us know.
    – Jon Barrie
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Wojciech Jastrzębski
    August 29, 2010 at 9:45 am
    Problem appears only with Magic Bullet.
    The other problem is, that sound is not exporting.
  • Jon Barrie
    August 29, 2010 at 9:50 am
    Are you running the latest update? 4.2.1?
    – Jon
    Jon Barrie
    aJBprods
    August 29, 2010 at 10:27 am
    yes, master collection cs4 is up to date.
  • Mike Velte
    August 29, 2010 at 10:31 am
    The sound is likely exporting as a separate wave file.
  • Brian Louis
    August 29, 2010 at 12:10 pm
    Like Mike said the audio is probably a seperate file, if you don’t tell media encoder under the multiplexing tab to mux the Mpeg it will export elemetal streams for use with Encore, you have to make sure you have multiplexing set if you want audio/video in one stream
    August 29, 2010 at 2:28 pm
    no, I’ve just marked the dvd multiplexing. the problem is that there was no audio file in the export path.
