Activity › Forums › Blackmagic Design › CS4 Driver Support for Windows Released
Posted by Kristian Lam on March 5, 2009 at 5:43 amHi guys,
Just dropping a note to let you know that CS4 drivers to support Adobe CS4 for DeckLink, Multibridge and Intensity was just posted on our software downloads page.
https://blackmagic-design.com/support/software/
regards
Kristian Lam
Blackmagic DesignJack Kelly replied 17 years, 5 months ago 12 Members · 20 Replies -
Achilleas Thessalos
March 5, 2009 at 8:06 amCongratulation!x3
Good jobDeckLink HD Extreme
Intensity Pro
Broadcast Converter -
Brett Kelly
March 5, 2009 at 12:08 pmOkay, great news we finally get drivers, however, bad news I have now totally lost audio output!!! Working fine before drivers and now nothing, checked audio output settings inside of Pro. Anyone else able to confirm this? I’ve emailed support already.
Randy Johnson
March 5, 2009 at 3:55 pmI guess what I wonder is if they were waiting for a Adobe update to release them and it has’nt come out yet. How good can these drivers be?
Randy Johnson
Rando1968@comcast.net -
Brett Kelly
March 5, 2009 at 11:43 pmI got sound working, I had to change the audio output settings from blackmagic as well as player setting from black magic to adobe player and I got sound back hope this helps someone else.
Kristian Lam
March 6, 2009 at 4:02 am[Randy Johnson] “I guess what I wonder is if they were waiting for a Adobe update to release them and it has’nt come out yet. How good can these drivers be?
“Randy,
We’ve worked around it.
regards
Kristian Lam
Blackmagic Design -
Troy Murison
March 6, 2009 at 6:55 amGreat news Kristian! May I ask about drivers for Mac OS? I see they’re still at 6.8.8 on the decklink download area. Are you close? Any info is appreciated!
-Troy Murison
Seattle, WA -
Yasser Amin
March 6, 2009 at 9:48 amGreat news but
1- did this new driver is stable with CS4 ?
2- did this driver solved the old problem with Decklink Extreme PCI and 4G ram issue with Vista 64 under CS4 ?
3- did this driver has this problem which described in this post
https://forums.creativecow.net/readpost/124/870359can’t test the new driver because I am in med project, I appreciate any answer for this questions
thanks
Tracy Peterson
March 6, 2009 at 3:24 pm“I got sound working, I had to change the audio output settings from blackmagic as well as player setting from black magic to adobe player and I got sound back hope this helps”
It totally does. I had this problem in prerelease as well. It defaults to the blackmagic in and outs. If you have the XLR in/outs connected to a mixer or other output solution, you should be fine, but if you have a hybrid of pc sound card and blackmagic, you won’t be.
Also:
There is not a “Blackmagic Audio” input for recording in the windows control panel. I thought there was one before, am I misremembering? I could have sworn that I had set my input to blackmagic audio at some point and recorded audio from soundforge with that mic input. Am I smoking something?
If it was removed, it would be a nice feature to have.
Tracy Peterson
http://www.onetwomany.com
