Activity › Forums › Adobe Premiere Pro › CS4 Can’t Change speed and opacity–same clip
  • CS4 Can’t Change speed and opacity–same clip
    Posted by Adam Chesbrough on July 15, 2009 at 10:32 pm
    When I change the speed of a clip I am unable to then change the opacity. Although I move the keyframes as if I am changing the opacity it does change in the preview screen (or when I render the project)…must be a fix as there is def a way to use both effects simultaneously. Please help, thanks
    Dell XPS 730 H2C
    Quad Core Duo QX9650
    Dual ATI 3870X2 Graphics Cards
    6 GB RAM
    Dual 1 TB Harddrives (RAID O)
    Windows Vista Ultimate 64 Bit
    Adam Chesbrough replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
