Activity › Forums › Adobe Premiere Pro › CS4 AVCHD Playback problems
  • CS4 AVCHD Playback problems
    Posted by Fred Campagna on October 22, 2008 at 7:36 pm
    I am having a horrible time playing back clips recorded on my HF-100. The playback in CS4 is very choppy to say the least. I have tried importing the clips to an external FW800 drive, importing to the internall HDD, and tried playing back directly from the card. In all cases playback in the source window was unacceptable. I have set playback quality to draft and made the preview size 10% and it still doesn’t play smoothly.
    I have a MBP 2.4 GHz Intel Core 2 Duo with 4GB RAM. The HDD is 7200 rpm.
    Anyone experiencing similar issues?
    Adam Chesbrough replied 17 years, 1 month ago 21 Members · 51 Replies
  • 51 Replies
  • Jon Barrie
    October 22, 2008 at 9:35 pm
    I have it running on a laptop core2duo 1.6, 2 gig ram 5400 SATA drive, playback is 1080 and realtime. Not sure why your desktop, with enough grunt, is struggling. Could be hardware drivers in the graphics card? Is your card running newest drivers? Are you on Mac or PC?
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Fred Campagna
    October 22, 2008 at 9:39 pm
    It is a MacBook Pro. It is strange. The audio keeps up, but the video lags way behind.
  • Ty Yachaina
    October 22, 2008 at 9:56 pm
    I’m having similar problems.
    CS3 is on my same machiene and playing back the same exact clips realtime, CS4 is lagging and chopping (Program and source monitor). It’s acting a lot more like a downgrade than an upgrade.
    I really wish i knew how to fix this.
  • Mike Velte
    October 23, 2008 at 11:11 am
    Virus/spyware software running in the BG will cause playback issues.
  • Eddie Lotter
    October 23, 2008 at 1:20 pm
    Perhaps this will help: FAQ:Why is the timeline responding so slowly?
    Cheers
    Eddie
  • Fred Campagna
    October 23, 2008 at 1:34 pm
    Unfortunately, I don’t have any of those issues or limitations on my MBP.
    I’m still not sure what the problem is.
  • Ty Yachaina
    October 23, 2008 at 3:02 pm
    I’m finding that Mini-DV tapes play fine with no choppiness, however the DVCam tapes that I use are the ones causing the problems.
    I’m gonna try to capture the tape itself in CS4 (As opposed to CS3 then bringing it over) and see if that helps any bit…
  • Mike Cohen
    October 23, 2008 at 8:36 pm
    Always test the video files via a media player, to see if they are ok or also choppy.
  • Fred Campagna
    October 23, 2008 at 8:38 pm
    Can anyone recommended media player that will play .mts files on a Mac?
  • Jiri Fiala
    October 24, 2008 at 10:09 am
    I thoughht CS3 couldn’t work with AVCHD? Isn’t AVCHD file-based only?
Page 1 of 6
